winnie
- Springfield, MA, USA
- Electric motor research
I was simply explaining why fixtures may say "60W incandescent" but how a 17W 100w filament equivalent LED may not survive in it.
60W filament lamp gets rid of most of the heat by infrared, which is radiated out, or absorbed in the reflector. The reflector in turn gets blistering hot.
A 17W LED lamp may put out maybe 5W of visible spectrum, but the other 12W has to go somewhere and much of that has to be conducted away the heatsink.
The amount of heat rejected by a fialment bulb as conducted heat is in single digit %.
Your numbers seem plausible.
Consider a 100W incandescent bulb. It might put out 1600 lumen. You are suggesting that somewhere between 1 and 9 W of heat are being conducted from the base of the bulb to through the lampholder. That sounds plausible to me; some small amount of heat will be conducted down the lead wires to the filament, and some small % of radiation will be intercepted by the bulb base and then conducted through the lampholder.
An equivalent LED bulb might require between 14 and 18 W of electricity. Your 5W of visible light photons seems about right; though if you have a poor spectrum the number could be higher. So with the LED you have some 9-13W of heat being carried away, much through the base and lampholder.
-Jonathan
