Well yes, but the same is true with a vast number of items- they only draw when in use. My car gets infinite gas mileage when it's parked in the driveway. The point is that when you use something, you get the equivalent usable work for less energy input.
You mean zero gas mileage, there are no miles when it's parked, no gas either. 0/0=0. If you push your car around with your own feet, the car gets miles with no gas use.
My point of "only when on" is that the "savings" is in that context. Parasitic is not. There is no savings when the item is off (not when the caomparison is two bulb types in the ON state).
Instead of spending $6 to save $5, why not just run TV ads that say "
hey, turn off those lights you are not using", because when they are off, the more that are turned off, the less power drain on the grid.
When the power sources are lacking and the message is "hey, just turn that off", the power folks get lazy and see that the demand is now much lower, hence no need to maintain 20Gw generation when 10 is good enough, and then one day everyone turns all the lights and HVAC to ON. Voila, brown and blackouts.
Diversity in power use cannot and must not ever exceed max capacity. But, CA knows very well that their power is exactly that, not enough capacity. If people need 40Gw at any given time, then the power folks need to maintain at 40Gw(min).
