I roughed a house for seagull ambiance in the upper glass cabinets, used 10/2 romex back to remote x-former locations planned on using the little wiring compartments that they have but things have changed. Customer has no decided that they want to use LED strip lighting these have a class 2 power supply, since I used a wiring method described in chap 1 thru 3 must I still use the wiring compartment. In this same house they would also like to use these same LED strips in the stair tread nosing, to make fishing eaiser I plan on using a 14/2 cl3 stranded cable fished down the wall to a closet. I need to transition from the 14/2 cable to the LED in a small groove in the nosing, am thinking about a butt connector. The stair LED is also fed from a class 2 supply, am I missing some code application that will prohibit this
Thanks
Thanks
