Replacing high pressure sodium 250w with a led corncob bulbs. Google searching shows that the existing 250 watt S50 bulbs should have a start lumen at 29000 and mean lumen at 26100.
The supply house has 250w led corncobs (I'll check tomorrow for the exact info), google search shows the 250w corncobs replace 1200 to 1400 w HID bulbs and are rated between 30000 and 35000 lumens.
There are currently 5 high pressure sodium's lighting up a parking area. Will the new white light at 250w be too much after the lower lumen orange light? Any suggestions for replacement LED wattage (lumen) for these 250 watt fixtures that won't be overkill?
Thank you
Thank you
