gar
- Ann Arbor, Michigan
- EE
181201-2342 EST
George Stolz:
Visualize79 in his original post stated a problem, and he probably correctly concluded that fusing occurred as a result of a problem at turn on or off.
He could have run some simple experiments that might have indicated whether it was a turn on or turn off problem.
Then what? If no knowledge or equipment, then it is simply a long experimental trial and error process. Guesses of what to try.
It is probably self-evident that a sufficiently large relay would solve the problem. Without more information it is quite difficult from a remote location to guess at possible solutions. If Visualize79 does not know what is inside his components, and how these electrically perform, then he is left with trial and error.
Electricians are going to be confronted more often with new devices using electronic components, and internally complex circuits. More experience and knowledge will be needed.
There are quite possibly some ways an ice-cube could work, but I won't get into those. I think there are other reasons an ice-cube should not be used.
George Stolz:
