Electric-Light
I actually trust the LED depreciation numbers more than the T8 numbers. Many of the LED estimates have turned out to be conservative as they get more data.
It sounds like you might have some doubts about T8 durability. Page 11 supports what I said earlier on RE80 T8 lumen maintenance.
http://www.pnnl.gov/main/publications/external/technical_reports/PNNL-22727.pdf
The unusually high performing LED is the Philips L-Prize, which was very expensive. It was about $50 for a 940 LM lamp and it was more of a publicity generating product than anything. Something unusual about this lamp is that phosphors are physically separate from the LEDs.
Solid state fluorescent lamps(LEDs) as well as normal FL lamps benefit by lower intensity operation to increase lumen maintenance and lumens per watt. In quest of lower production cost, some consumer LED lamps have actually come down in specs. CREE brand for example uses less than half the number of LED chips and drive them harder. This lowers the LPW as well as lumen maintenance. T5HOs and CFLs don't hold their lumens as well as T8 for the same reason.
Premium RE80 4' T8 lamp-ballast systems are 100-103 lumens per watt and the most important thing from here on is using a high efficiency fixture.
T5HO is a good choice for high-output applications like corridor or high-bay
You can get about 90 LPW delivered with premium efficiency fixtures.
Examples for 18-20K lumen per fixture range generally used to replace 400W MH
High efficiency...http://www.gelighting.com/LightingW...UltraStart_Watt-Miser_System_tcm201-22261.pdf
Or long life...
http://www.gelighting.com/LightingW...4_T5_Starcoat_Ecolux_XL_F54T5HO_SellSheet.pdf
In summary, fluorescent systems can provide a maintained output level in the 80-90 LPW range while LEDs speculated maintained performance can be 70-110 LPW, but in applications competing with linear T5HO and T8 lamps, cost per million lumens is far excessive. At common commercial and industrial utility rates, the simple payback can exceed ten years just for the fixture price difference. In the real world, proper adjustments should be made for time value of money which will extend the time or even eliminate the possibility of breaking even.
When I compared the prices on 100lm/W Philips LED retrofit kit vs 85 lm/W FLUORESCENT ES8 kit+2 HPT8 60,000 lamps, the LED was $17,000 more expensive per million lumen. This thread is about new buildings, but this cost gives a good general sense of what you might expect in cost difference between premium T8 vs LED fixtures. The LED option may turn out to be the Least Economic Design.
This was true years ago. Lamp cathodes were left on after start. The current NEMA Premium programmed start ballasts pre-heat, start and turn off the heaters, so they do not use more power.And the T8 numbers seem to be really dependent on starting intervals - put a T8 in a toilet room with an occupancy sensor and you either have to use a rapid start ballast which uses more power, or the lamp life will tank.
There is also step dimming that dims down all the lamps instead of shutting off some lamps. This one can go back and forth between low and high modes without lamp life reduction or starting delay and less expensive than full range dimming.
Dollars per million lumens is a whole different subject.
All of those things above add up to $/ML. Many LED fixtures have bells and whistles to justify the higher cost as they're not able to come up with economical stripped down version.
