LED Lights flickering
Sure does sound like an open neutral somewhere. Have you put a voltmeter on the lights while they are flickering? Maybe somehow a mistap, and lights were in series with the lights in the living room? Maybe replace one of the LED’s with an incandescent, and see if that changes anything?
I'll try it. Thanks.
Do you think a different type will not flicker. All the LED bulbs are not flickering. Just the trim with LEDs made to the trim.
I am running into the same issue. I just went to a job and everything was working fine for a few weeks. Now every single light in the house that is on a dimmer is flickering my thought is possibly a bad neutral I'm heading back there tomorrow to do more investigation
Sent from my SM-G998U using Tapatalk
