Onlyincali
- California
I will be installing new recessed puck led lights in the top of two cabinets for a long time customer. The customer prefers these lights https://www.build.com/wac-lighting-hr-led90-30/s1091443?uid=2620565 which I believe will be paired with this transformer https://www.build.com/wac-lighting-en-2460-rb2/s894548
Here's the problem
Customer does not want to add a visible switch to the backsplash under these cabinets as it is covered in a fancy, eye-catching backslash. There are no other places where a dimmer switch can go without being odd. He wants a small "touchpad" dimmer or slide dimmer mounted under the cabinet or on the inside of the cabinet. I can not find a ELV touchpad dimmer for the life of me. Do they exist!?
Something like these below would be PERFECT but I don't believe it will work with LED lights that require a class 2 transformer.
https://www.lowes.com/pd/Utilitech-..._clickID=94fd5712-1ca6-4fca-8ae6-2bc59edf75f0
https://www.amazon.com/Lutron-TT-30...coding=UTF8&psc=1&refRID=BEQEYDWVMJR5M0JTEHXQ
Is there anything out there that is similar to the above two options but will work with these led pucks? Any other solutions that will be energy efficient, warm white light, dimmable with a small hidden switch? hiding transformers, receptacles, etc. in the attic directly above these cabinets is not a problem, if that matters.
Thanks for any advice/suggestions you can share.
Here's the problem
