tsherrod
- United States
I have a client that has one of her living room recessed lights periodically cut off and then back on. There are 8 lights in the living room (ALL LED) and are controlled by Lutron Maestro companion dimmer switches. The light that cuts on and off is closet to the switch and all the other lights are fed from it, as far as I can tell. I have tried changing that particular recessed housing unit to no avail. I then suspect it might be the dimmer switches are overheating or failing to carry the load but the customer told me it happened before those were installed (acknowledging she could be misremembering). Their house has had several lighting issues over the last few months, but I have not been able to find any signs of a loose neutral. Anyone have any ideas of what would cause the one light to cut off and back on without affecting any of the others coming off it?
