We are designing a sports field lighting project in which the sports lighting vendor is indicating the LED lamps on 1 post for example has a full load current of say 36.5A (480V 3-phase). They note to base the overcurrent device using this full load. Now you apply 1.25 for continuous load and get 45.6A which would be a 50A breaker. Typically I believe you would apply NEC 210.23(C) for this. However, how would this be applicable for LED lighting as they are not typically lampholders?
