The LED trims made by Feit have been in place for the last 4 years on Lutron Diva dimmers. In different rooms and different dimmers. Now they decided to flicker when dimmed. I am sure it flickers when on full brightness I just can't see it.
Voltage reading on the breaker is OK 120V, I connect a incandescent bulb and it does not flicker, yet the rest of the LED still flicker with the incandescent still on the circuit, With all of the LEDs ON, the circuit breaker has a slight buzzing noise, confirmed the noise to that breaker with a stethoscope. Installed a new breaker (maybe old one had a bad contact) still flickering. Installed new dimmer (Lutron Diva) still flicker. Checked voltage at the LED trim 103volts.
Even though the chances are very low, but I don't see why all of the trims and dimmers would go bad at the same time. Next step i step is check voltage reading in all of the rooms and see if consistent 103V. 103V is puzzling to me.
Your suggestions please.
