LED trims just started flickering
Solid state dimmers accomplish their job by “flickering” at a slower speed to give you the appearance of dimming. Since the issue is that your are seeing this on its dimmed setting I would remove the faceplates and adjust the “low end” dial or slide on the left side near the bottom of the face of the device. If it doesn’t have this tuner, per lutron, it is not LED compatible. See attached picture
