PetrosA
- Lancaster, Pennsylvania
I recently installed four Sylvania 15W PAR30/LN LED lamps for a customer. There turned out to be a three way dimmer in another room that neither I or the home owner was aware of that caused issues with the LEDs turning off and on. Long story short, I consulted with Sylvania's tech support and got a list of compatible dimmers for these lamps. Because there are no compatible three way dimmers, the home owner agreed to let me eliminate the switch in the other room and install a compatible dimmer in the room with the lights. I picked a DVLV600P as it was readily available. Now the fun starts.
When the homeowner first called me back about this, I went and hooked up two multimeters (meter A inline between the hot and the switch for current, meter B measuring voltage) and did some data logging on my tablet with an additional math function of A*B to get watts with the original Ariadne 603P still installed. I saw that the lights were pulling 95-96W on full bright. If I started lowering the dimmer, the first 1/8" of the slide down would actually increase the wattage consumed by the lights, up to about 130W, then it would drop suddenly to about 75-80W and dim normally after that. I figured that might be typical for an incompatible dimmer. I also saw there were no serious voltage issues.
Today I did a control measurement with no dimmer, and found that the four 15W LEDs consume about 75W wired direct (18.75W each, which makes sense...). I then installed the Diva LV. With that dimmer they consume about 101W on full bright but it increases to nearly 150W as you start to lower the dimmer until you hit the sweet spot where it actually starts dimming the lamps! At the 150W spot, the lamps are really humming (17' ceiling and they were easy to hear). I left it at the 150W setting and after maybe 1 minute the wattage dropped to about 129V and stayed there for another 15 minutes till I changed the setting.
I explained to the customer that it's important to make sure the dimmer is either all the way up or dimmed to at least 75% or so otherwise the lamps may hum and they'll use more electric than they should. Obviously, this makes me sound like a crack head, but what's a guy to do?
Can any of you with high dollar power analyzers, some LEDs and a compatible dimmer confirm this phenomenon for me? Obviously it would be great if you had four 15W PAR30/LN Sylvanias and a DVLV600P dimmer, but any readings will be interesting to me at this point. I don't know if these readings are a shortcoming of my test setup, or whether LEDs and dimmers are really performing that strangely, and poorly. Any thoughts?
Voltage was measured between hot and ground with an Agilent U1211A, current was measured inline between hot and switch with an Agilent U1272A for a more exact current reading than my clamp meter can do. I can make .csv files available if anyone's interested.
