Toxicity and deleterious are better stated as "Negative health effects" in recent studies on blue light.I do not see how light can be toxic. Unpleasant, OK; eye damaging if it is too bright, sure, but toxic? Toxicity is a chemical effect.
Actually low pressure sodium is more efficient but the color is not pleasant, the astronomy folks like it.It seems pretty clear that mtnelect has a problem with LEDs that don't work properly. I strongly agree on this point.
I've followed the development of LED technology for years, and also followed the hype and misrepresentation by the LED manufacturers.
The technology has matured tremendously, and now LEDs work amazingly well for many (but not all) applications.
I was taking issue with the broad brush misinformation style of talking about LEDs, rather than the focus on the specific and real failings.
If the only factor that we cared about was luminous efficiency, we would be using sodium vapor lamps.
Jon
Umm, what flicker? Unlike LEDS and discharge sources, incandescent (or "black body") sources have hysteresis, and that's much longer than a half-cycle. So do some of the phosphors used in LEDs and CFLs (which also tend to smooth out their flicker).the analog sine wave flicker from an incandescent
As shown in the two images, LED light and incandescent light do not have the same characteristics and LED light, by virtue of the excessive amount of toxic blue wavelength light, is a low-quality light.
It should be noted that the reason that the manufacturers use blue wavelength light in LEDs is because this is how they increase luminous efficacy and reduce costs. The industry claims that LEDs are energy efficient are false because LEDs don’t provide the same high-quality spectral distribution as incandescent. If the manufacturers were to make LEDs with the same quality of spectral power distribution as incandescent, the luminous efficacy would be no better than incandescent.
More information to follow ...
One application where some LEDs do not do well: My sister gave me for Christmas one year a BBQ light - a battery operated LED set on a gooseneck with three strong magnets to attach it to the grill frame. It works great except for one rather important thing. The light from it has virtually no red component, so rare meat is indistinguishable from well done. I use it for a reading light; it is fine for that.The technology has matured tremendously, and now LEDs work amazingly well for many (but not all) applications.
Without resorting to actual numbers, probably the least "efficient" lamp in the last 40 years was the 93w incandescent; slightly less heat but even less light. They were on the market for, what, a year or so? Then the rightly vanished.
For reference, the ideal black-body radiator at 4000 deg K has a luminous efficiency of 7.0% or 47.5 lumens/watt (roughly double that of a tungsten filament quartz-halogen lamp). Crank the BB up to 7000 deg K and those almost double.
(Sung to the tune of "My Bonnie Lies over the Ocean"--
Black bodies give off radiation,
and do so continuously,
and do so to Planck's theory.)
Don't you get hot?I use it for a reading light; it is fine for that.
I'd say anyone that marketed it as a grill light is who went wrong here.One application where some LEDs do not do well: My sister gave me for Christmas one year a BBQ light - a battery operated LED set on a gooseneck with three strong magnets to attach it to the grill frame. It works great except for one rather important thing. The light from it has virtually no red component, so rare meat is indistinguishable from well done. I use it for a reading light; it is fine for that.
And it started with LED vs incandescent (a non-ideal black body).That applies to light bulbs which are basically BB radiators or close. [...]
So I don’t see where BB/WB has a place here.
