Pretty damn close equivalency compared:This is how you make the A vs B comparison
I am comparing LED and 6 lamp T8 HBF with 28W HPT8 that ends up giving you around 16,000 delivered lumens with L90 of about 60,000 hrs.
Reference I used for the LED:
http://www.acuitybrandslighting.com/Library//LL/DOCUMENTS/SPECSHEETS/IBG.PDF
Look at "comparable light sources" column. You may notice that equivalency reference is much more reasonable and is far less bloated than it was years ago. Some of you may also notice that they started using "lumen compensation" instead of solely using "lumen management" in reference to nLight N80 option that maintains the same output by adjusting the dimming ballast to increase power consumption according to the pre-defined LED degradation curve and power-on hours to cancel out the effect of cumulative LED degradation. Once the 25% reserve power is maxed out, it runs at the full power and continue on by losing light output as LEDs lose output.
When it was freshly introduced,
Lumen Management
More recently,
Lumen Compensation
Fluorescent: 16,500 LM per 188W @ 277v $106.24
Lithonia IB 632 188w. Ballast and lamp together makes light at 95 LPW
The fixture is 92.3-92.7% efficient. This brings you 16,500 delivered lumen using 188W. which is 88 LPW
Fixture is $70 @ homedepot.com (current price, 20% special in place)
$36.24 @ $6.04/ lamp PHILLIPS 28W 2XL ADV841 ~60,000hr-90,000 hr lamp (L92) (HDSUPPLY)
LED: 16,000 LM per 112W @277v $385 60,000hr (L88)
IBG 18000LM SEF AFL GND MVOLT OZ10*** 40K 80CRI DWH IBG 18L MVOLT
The stock option 18,000LM fixture. The "HEF" appears to be made to order. I am not sure how much the HEF option adds. It could be disproportionately high like the top of the line CPU vs a notch or two down. I assume that the fact it's not standard stock item means it's not going to sell well enough to justify ongoing production.
$385, also homedepot.com
16,000 delivered per 112W @ 143 LPW (per Acuity spec sheet)
*** if utilized, it incurs 0-10v wiring, controls, and setup expense, because it is not already in place for the existing 175W MH
The amount of account discount is probably not the same between the highly fluid LED vs pretty much non-changing T8, so let's just use public portal pricing.
Incremental cost per fixture: $278/fixture
Power reduction/fixture: 0.076kW
demand saving per fixture $10.944/year/fixture at $12/kW
Industrial energy rate for facilities that use these lights like 8-10c/kWh in high priced area?
665.76kWh/year difference if 24/7
You need 3,089 kWh to get $278 back @ 9c/kWh. Simple Payback Method.
You can make money by charging a fee to lend money. You have to pay a higher fee to borrow money. The difference goes to the bank's pocket. If you assume you can borrow the additional $278 needed for LED option for no charge, it takes 4.63 years @9c/kWh to break-even. I'm going to ignore the $10.94/year demand saving estimate in exchange.
