Does it make sense for a journeman electrician to get leed certified in an effort to advance ones career? I would think it makes sense for an EC to be leed certified but are there any benefits from having the emloyees certified?
For the the EC well sure thats a Resume' stuffer for sure. Required, well if you live in a green neighborhood? Well the peer pressure might be the cause and the effect here. If you can afford to get it, go for it, your employee's need to be informed and aware of it. Here's my take on it.
The Owner and the Designer have to apply from the beginning to get the project LEED quailified,
then they get it certified, via inspections ( I think thats right )
With New construction its just spec'd or designed in, (just install this)
frankly its almost a no brainer. In this case it'd be a just a high end install.
In refit /upfit (whatever), it's also usually spec'd., you'll have to state here's why your using this,
doing that, IE back to you'd have to make your employee's attentive.
LEED is not "code minimum" its usually "grand maximum"!
There will be more applications for all trades, ie more of everything,
better install of materals and usually a greater everything. It frankly doesn't effect us electrically other than install more sensors/dimmers or sudo smarter circuitry.
To gain an LEED certification the guide lines are set (as stated above- but not just limited to what was listed) there is usually is alot of the things that are not left untouched as to the big picture.
This stuff /project is inspected and the company thats doing the inspection is qualified to do the inspection.
