I understand the left hand rule. This will tell you the direction of the magnetic field around a conductor. So, if this is correct does the magnetic field change directions 60 cycles a second.
I know it was taught at least 35 yrs ago.:grin:I don;t think the left hand rule has been taught in theory for at least 40 years (iwire?)
I don't know why you would suggest the concept (it is not a theory) is not accurate. It is based on the mathematics of magnetism, and is a simple rule to assist in determining direction without delving into the core equations.(Neither theories are accurate FWIW).
No, a solenoid doesn't care about the RHR or LHR. The coil will magnetically attract the plunger regardless of the direction of the current, or even if the current is AC or DC. A permanent magnet plunger will be different, but this is not as common. Motors, on the other hand, are very much dependent on the direction of the magnetic field.The left hand rule is part of the theory that is taught for determining how a solenoid will operate. it definitley is more applicable to DC rather tnah AC circuits.
Keep in mind the left hand rule is based on electron flow when most people follow the hole flow theory (Current flow from + to -) in which case the right hand rule applies (Neither theories are accurate FWIW). I don;t think the left hand rule has been taught in theory for at least 40 years (iwire?)
Why is it that "most people" follow the "hole flow theory" instead of electron flow? I've never understood that.
Isn't current flow a measurement of electron movement? If the electron is moving from left to right, the hole is moving from right to left. So most people will say the current is flowing from right to left? I'm hard headed. Just doesn't make sense to me.
As to the original poster's question, yes, the magnetic field does constantly change, and that is why transformers work on AC but not DC.
A 60Hz sine wave has 120 zero crossings (change in direction) per second.
Most people have learned that current flows from positive to negative, electrons "flow" from negative to positive. Not sure why theory is taught that way, it just is. + to -.
Actually, Franklin didn't get the flow wrong, he got the polarity of the charge carrier wrong. He assumed the charge carrier to be positive, but we later learned that it was negative (the electron).Because Ben Franklin had a 50% chance on getting electron flow direction right and he didn't. So it has always been taught "+" to "-" when as you stated electron flow is "-" to "+". Well for fundamental theory it's taught that way.
I learned "hole flow," and the right hand rule, in college. Shortly thereafter, I learned "electron flow," and the left hand rule, in the Navy. I think the Navy still teaches electricity in terms of electron flow.I don't think the left hand rule has been taught in theory for at least 40 years
It amazes me that principles of electric are still referred to as theory.Either way works just fine, as long as you don't mix theory.
