Legal use of connector? (Or, Spot the Violations!)
peter d said:
That often happens with the nonmetallic lampholders. I have no doubt that you understand what happens when you heat up urea. :)
For that very reason I avoid the non-metallic lampholders and use the trusty porcelain ones that have been made since the dawn of electricity.
porcelain is also non-metallic. You should clarify and say plastic instead of non-metallic as I have never seen a metallic keyless.
iwire said:
410.47 requires that lampholders be installed as lampholders only...
Hmmm... never realized installing these
were a violation...:confused:
