Security
- Dallas, Texas
The company I work at is manufacturing poles for CCTV cameras and equipment, and we want to make sure that the wiring is legal - both the wiring done here and also some preparation/guidance for the installer to remain legal.
I have spent many days searching here and elsewhere, and I may have confused myself with all of the information that has been discussed and NEC code. So I still have some questions that I can't seem to find answered adequately.
I have 4" square poles to work with, and they are dedicated to CCTV equipment (no luminaries) - all high and low voltages are part of the same system.
Here is what we are proposing on some models:
- 120V wiring with MC from the handhole to the top of the pole - receptacles at the top of the pole in a large built-in junction box, controlled by a GFCI Module at the handhole (accessible). Ground wire will be connected to the grounding lug inside the pole.
- Low voltage and 120V will both reside in this junction box (camera connections and receptacles). There is a 3" hole entering this box from the pole top, so 2" separation is possible.
- Some poles will contain wireless equipment, but some will require coax and/or Cat5/6 down the pole to the handhole.
My questions:
Is this legal?
Do we need to have a divider anywhere? (if so, what materials may be used?)
Installers will be instructed to bring in power and coax in separate conduits - so what can be done to make the connections legal at the handhole? (from conduit(s) to our wiring)
Any other issues you can think of?
Thanks in advance - I've seen some great answers here during my searches.
My questions:
Is this legal?
