zog
- Charlotte, NC
LarryFine said:Wheatstone bridge?
A microhmmeter is a wheatstone bridge
zog said:Actually there is no way to measure any resistance,
iwire said:I agree but I bet that thought will cause a bunch of posts.:smile:
gar said:Ohmmeters and bridges are not the same thing and should not be equated as the same.
gar said:...A bridge for precision resistance measurement is a null balance means for comparing resistances, and does not require knowing current and voltage to determine resistance. This is also an answer to an incorrect statement somewhere on this forum that you can not measure resistance, but must calculate resistance from current and voltage. ...
zog said:... A microhmmeter is a wheatstone bridge.
zog said:... Your definitions of ohmeters and microhmeters are just your opinon and go against equipment manufactures definitions.
gar said:080905-2230 EST
When you follow this problem from Wheatstone bridge via Wikipedia in the direction to a solution the result is incorrectly described and incoherent. A correct discussion and correct diagram exist on p 80 of "Basic Electrical Measurements", by Melville B. Stout.
That's true. The key word being "relative"gar said:... In the early days accurate volt and ampere meters did not exist, yet it was probably possible to measure resistors relative to each other within 1 part in 100,000. ...
