gas powered baby (you can get a right angle attachment)
(plus the fumes run the other trades out)
That's a new one on me.
I've never seen one of those.
steve
From the supply house. This was years ago, I bought my first one in the '80s.
I believe you can still get them from Milwaukee.
steve
And like any tool, you need to learn how to use it. Properly. And safely.
Once you learn that, it works great.
We're talking about the unit with the chuck and handle at 90 degrees, right? Way back in post #2?even used properly and safely it'still a wrist breaker
What drill is the best for drilling out wood studs for housing rough in?
Thata one - bar none.... I've used one for years too - Makes for great air guitar, and if you score some quick release bolts for a bike seat - it makes a quick change out to a regular right angle - although making it a dedicated is probably what it will stay. Big back saver...Here is a picture of the gooseneck I used. There is little need for a ladder in standard 8ft ceilings, and virtually no bending down as well for lower holes. I used these many, many years.
How mnay #12's can you fit in that hole and be compliant?.50 cal machine gun.
Many interior walls are not framed with 2x4s.
QUOTE]
Then what are they framed with? In my neck of the woods, almost every interior wall is 2x4. The exception might be a 2x6 with plumbing present.
c2500
Such as a 2 story dwelling. Have you noticed what the plumbers can do to the framing of a home?:-?
You think you might even get around to building it - as opposed to standing around a table for five years talking about it?Imagine what would happen if all the trades worked together as a team...in addition to anyone involved in the design process. We could actually build the "Perfect" house.
c2500
Catch a nail and you're off to the ER. IMO too heavy, and WAY over powered. A D-handle you don't even have to wrestle it, slow enough that it cuts wood rather than melts it - heating the bits so they dull too quick - but fast enough let the draw screw pull at the correct rate, and just enough power to stall if it bites anything bigger than a 16 nail. It's the perfect balance of power/torque and speed for wood framing with the 7/8" auger bits I use - and at that speed they last a lot longer. And that extendo necked one - there is nothing like it. Drill cielings from the floor, and I also have a neat trick or two so I don't pull cable on a ladder either.The Milwaukee Super Hawg is the only drill I use on roughs. At 2000 rpm and a new 1 1/4" bit, it's like a hot knife thru butter. I'm done drilling a 6000 sq ft house by lunch.
~Peter
Definitely not OSHA approved.
No they call the A-team and SWAT. Maybe ChiPs too.You honestly think if OSHA showed up and you were lugging a .50-cal automatic around,
they're going to write you up for that?![]()
WACO didn't have that type of fire power and they brought in tanks...Probably not, but I'm sure the local police and ATF would like to have a word or two thousand with me.
Back on topic, there's been some pretty nice drills shown here. The one the with pole extension looks quite useful - my question with that is does it hold up (is it sturdy), and approximately how much does it weigh?
