Hello all, just wanting to create a thread so we can see what multimeter(s) you guys are using out in the field to get the job done every day.
Job: Industrial electrician (Mill)
Multimeter(s): Fluke 381 Clamp Meter
Fluke 1587 Insulation Tester/DMM
Pros: Fluke 381 - quick and easy to take ac amp readings, screen is magnetic and and be taken off the clamp meter and placed on cabinet wall.
Fluke 1587- great for testing anything from 120V-480V, has low pass filter for accurately testing VFD outputs, able to test start/run capacitors with it
Cons: Fluke 381 - sometimes clamp doesn't fit around wires easily at back of industrial control panels or around large AWG conductors that can't be moved easily, can't test start/run capacitors with it.
Fluke 1587 -each time to take ac amp readings (without breaking the circuit), have to unplug the standard test leads and plug in separate amp clamp
Post your multimeter and any other comments, recommendations, or tips/tricks.
