kwired
Electron manager
- NE Nebraska
- EC
My question is if you are working on a 3 million dollar mansion do you need 3 million dollars of coverage? How likely is anything that happens as a result of your work going to cause complete destruction of everything? Most incidents that may do that would likely have fire involved, if codes were followed shouldn't there be code required fire barriers in some points, maybe even sprinklers or other items that should reduce the chance of total destruction? If not could you file counter suit (or something similar in principle) that will at least lessen your liability in the case?I had to bump my policy from 1 mil to 3 mil to accommodate potential losses on a couple of McMansions I've had to do some work on. The difference in cost between those levels was very minimal, also upped tool coverage level. Inflation also has taken smaller homes replacement levels much higher pushing policy coverage level needs higher too.
That said I do agree that the way things have gone it possibly is time to re-evaluate how much coverage one maybe should have.
