I install home automation, home entertainment and home network systems in Dade, Broward and Palm Beach counties. Specially we install Cat5e/6, RG6, speaker wiring and other AV/Audio cables in walls and ceilings. We subcontract out all high-voltage and alarm system work as we do not have the required licensing.
I've talked with the Florida Department of Business and Professional Regulation with regards to licensing requirements for the work that I noted above and was told that no license is required. I've heard different stories from other individuals in the high and low voltage business. Can anyone give me a definitive answer on whether a license is required to run Cat5e/6, RG6, speaker wiring and other AV/Audio cables in walls and ceilings? If a license if required, which one?
