Light opinion
Fulthrotl
~~Please excuse the mess. Sig under construction~~
What's that all the way up under the eves in the soffit? Looks like two recessed lights??
-Hal
they aren't the same distance from the crown of the roof.
not that i'm bein' fussy or nuffin....
Knuckle Dragger
Master Electrician Electrical Contractor 01752
I thought that at first too.
It may be an optical illusion they seem to be on lined up properly on the clapboard.
nickelec
Extension ladders used as planks? :?
No they were using those as a shelf for materials they had the aluminum ones , lol does anyone have an actual opinion of if I should put a light by the door Im starting to think not
Sent from my SM-G965U using Tapatalk
PaulMmn
1 light, centered above the door.
MAC702
You should know better than to post a pic and only expect comments about YOUR question! :lol:
And if I hadn't asked, I would have missed the planks below and closer to the house, and now see the ladders as shelves. Thanks! I just knew there had to be something I was missing.
As for the light, I think you are already served by the central location, unless you need something switched at the door, and that isn't able. If you are doing a covered porch, then I'd go with a light inside of that, instead of on the house wall.
