rasmithircgov.com
- Florida
Re: light over tub
Here in Fl. the FBC says floors and walls shall be contructed of smooth corrosion resistant and nonabsorbant water resistant materials of a hieght of 70". So I can see taking the hieght in concideration. But nowhere in the NEC does it concern itself with hieght. Now if we look at switch requirements around a tub nowhere in the code does it say a distance away from a tub it has to be. This to try to establish an area at said location horizontally.
404.4 Switches shall not be installed within wet locations in tub or shower spaces unless installed as part of a listed tub or shower assembly. I was looking at all this to try to find a more specific area of dampness. Within tub or shower area.
So what is within, how far away is it? Is it the innerwall of the tub, the outside wall of the tub? So I would suggest right or wrong the code in itself with its vagueness is opening this up for interpitation and if the inspector wants it rated for damp or wet it is up to him only because of the vagueness of the code itself and hopefully all are concistant in that juresdiction.
[ August 05, 2005, 08:26 AM: Message edited by: rasmithircgov.com ]
