Alwayslearningelec
- NJ
- Estimator
Morning. So there is another contactor bringing the feed from the panel inside the building to the two j-boxes(100' from panel to j-box) in the upper right hand corner. We are to extend the feed from there to the S1 & S2 fixtures(from j-box to last fixture 250'). Not able to get(right now) what size feeder they are running from panel. How can I calculate approximate size of main feeder to keep VD under 2.5%? Do I just convert the watts to ampos and total the amperage for 1 circuit and but that in VD calculator or just use the 1P-20A breaker. Do I calculate all of them on same circuit? After I hit underground "homeruns" boxes I can branch off with smaller wire to light poles correct? It's 120v. Thank you very much.
