Actually height will effect wind velocity. The wind can be blowing here on the valley floor at 20 mph, but you gain a little elevation such as going up to one of our water tanks and it can be 10-20 mph faster. Also buildings blocking the wind can affect it.
So this parking garage is out in open space? Good chance it is there because there isn't room to spread all that parking space over grade level - so other structures are probably necessary to take into consideration on how they impact wind speeds.No, there are frictional effects on wind velocity near the ground. As you go up in elevation, wind speeds increase. I'm pretty sure that in the open, 60 feet about the ground will be windier than 10 feet above the ground.
Cheers, Wayne
Pretty good chance whoever designed it took that into consideration when selecting materials - OP is asking best way to get them hoisted into position.
Every place has a minimum that they have to design to, here we are an 80 mph wind zone.So this parking garage is out in open space? Good chance it is there because there isn't room to spread all that parking space over grade level - so other structures are probably necessary to take into consideration on how they impact wind speeds.
I realize that, but if installing them 60 feet above ground level do you have a different wind speed then at ground level?Every place has a minimum that they have to design to, here we are an 80 mph wind zone.
No, but that wasn't the question. We only have one four story building in town and the wind once clocked out at 105 mph up there.I realize that, but if installing them 60 feet above ground level do you have a different wind speed then at ground level?
