We removed a light pole last week that was concrete with some kind of decorative aggragate(spelling). Had to weigh 600-800lbs. Use a fork lift and a strap that we worked up the pole then had a strap and a clevis and piece of strut in the hand hole on the bottom to tension it. The whole rodeo seemed unsafe. Straps were somewhat worn. I couldn't read the load limits on them. Limits on straps are probably well over that. I'm not sure a clevis and piece of strut in the hand hole is a safe way to pull something like that. I don't have a lot of light pole experience but it just felt like we were relying on luck to safely pull this pole. I was wondering if there was any load rigging information on the web or what is considered the industry standard safe method to sling poles. I'm also wondering if on loads any type of backup sling is required. I've never seen one on any heavy(2-4000lbs) loads I've helped sling. On all the big stuff I've slinged if one strap or chain fails you lose the load. Seems unsafe to me.
