gh0st
- California
- Designer
Not required. The pole is grounded via the EGC. You should not directly connect an GEC to the EGC, of course they're all connected to the GES.
No, it is not. The provision that was quoted in a previous post though does refer to connecting the electrical system to ground 250.4(A)(1), and nothing directly to do with the EGC.
The ground rod at the light pole is called an auxiliary electrode by the NEC, since it’s not required, the rules for connecting it are not as strict, for example no minimum size wireNot required. The pole is grounded via the EGC. You should not directly connect an GEC to the EGC, of course they're all connected to the GES.
It’s often done but serves no purpose, and the subject creates substantial discussion.
Sorry, but logically, the burden of proof is on you to show that it does something beneficial, not somebody else to prove to you it doesnt do anything beneficial. I put wheaties in my gas tank. Prove to me it's not beneficial.What makes you think they don't?
JAP>
I already did in post 22.Sorry, but logically, the burden of proof is on you to show that it does something beneficial, not somebody else to prove to you it doesnt do anything beneficial. I put wheaties in my gas tank. Prove to me it's not beneficial.
If there is any benefit to electrodes at poles whatsoever, lightning dissipation would be it.
Just curious what do you mean by caisson?on existing older caissons
Right. The last sentence was a joke and an example of the flawed logicIsn't this a contradiction of terms?
In this case I would think the burden of proof would be on you to prove to me that putting Wheaties in your gas tank would be beneficial.
JAP>
Do you really believe that a light pole struck by lightning would be saved by being wired to a ground rod?I already did in post 22.
Not required for light poles, but, You can't say a ground rod has nothing to do with a lightning strike in the electrical field when we use them as a means to connect our grounding electrode conductors to the earth.
JAP>
not in the least. so why is there such a widespread believe that it will be helpful?Do you really believe that a service entrance struck by lightning would be saved by being wired to a ground rod?
JAP>
The code is quite clear about the role of grounding electrodes in general, of which a ground rod is just one. Protecting light poles from direct lightning strikes is not on the list.I guess we'd have to first hear what you think the actual role of a ground rod is.
JAP>
