vonleuthardt
New member
- Minnesota
Here's the question?
1)I have an open supply conductor OCS(Overhead Catenary System) above 750v (actual 834Vdc)strung horizionally beneath a grounded steel Bridge structure member with 8" to 9" vertical clearance with no insulating barrier.
a)What does the code allow for mimium vertical clearance between contact wire and bridge structure?
b)What does the code allow for mimium vertical clearance between contact wire and bridge structure with 1/4" thick +/- Glastic or Fiberglass Board barrier installed?
c)Answer:Code references and tables?
2)Qaulified Person? In the hiring of an apprentice Lineman and/or Electrician working live voltages in excess of 600 volts (hands-on and/or prox)what is the base line for work experience, education and training requirements?
a)What are the NEC, NESC code references, OSHA, IBEW and Industry standards?
vonleuthardt
vonleuthardt
