allenwayne said:Grab a level and make a vertical line from the edge of the tub or shower.If the switch doesn`t encroach this area it is code compliant.Do I agree, NO.Does my opinion make a difference NO !!!!!
stickboy1375 said:Why do you not agree? You can install a switch outside correct? it rains outside last time I checked...
Jim W in Tampa said:We can and do install receptacles outside.Does that mean i can put one in the shower ? No
stickboy1375 said:my point was since no one got the point was, HOW come its a ISSUE to install a switch NEAR a SHOWER, but nobody has a problem installing one OUTSIDE???
stickboy1375 said:where did receptacles come from? we are talking about switches... my point was since no one got the point was, HOW come its a ISSUE to install a switch NEAR a SHOWER, but nobody has a problem installing one OUTSIDE??? IS THERE A DIFFERENCE? besides being naked....(hopefully)
iwire said:Who says I don't have a problem installing a switch outside?
If I install a switch outside it will be weatherproof, check 404.4.
Jim W in Tampa said:If a switch is safe then why would a receptacle not be.I personally dont think its a smart location for either receptacle or switches.We would never let you put a receptacle or switch within reach of a hot tub but its fine with a metal bath tub.Why !!!!!!!!!!!
allenwayne said:Now what kind of weatherproof cover are you using makes a difference.We went through this awhile back and it was determined that only a weatherproof cover designed specifically for a switch or an in use cover were able to be used.
Even though like a weather proof single device cover has the cut out in the flap for a toggle switch,like a T&B WR74C . It is listed as a receptacle cover and not to be used on a toggle switch.
stickboy1375 said:Yeh, the hottub issue probably has to do with bonding, but the bathtub/shower switch location has to do with water entering the switch box... the code is protecting the switch, not the operator, the reason I believe this is that your allowed to install a switch outside with a weatherproof cover, hence to keep moisture out.....again nothing to protect against shock... otherwise it would have to be on gfi protected circuit... IMO.. any thoughts...
stickboy1375 said:I understand everybodys view on safety first, BUT if the NEC was worried so much about it then why not a 5' rule for a switch near a tub, it really must not be an issue according to the nec... my whole point was " whats the difference between outside install and near a shower install, the weatherproof cover for an outside location only protects the switch not the operator... sooooo how can someone disagree with a switch outside a shower but not a switch installed outside...? you can't have your cake and eat it too....
j_erickson said:Do you mean "in" the shower or "near" the shower. There is a switch near my shower for the closet light. The difference between it and an outdoor switch is that one is a wet location and one a dy location.
If you're asking "why is it ok to have an outdoor switch in a wet location but not a switch in a shower", I don't have the answer.
stickboy1375 said:no not in the shower, outside the shower area, People are worried you can flip a switch while still in the shower, yet I say you can be outside in a rainstorm and still flip a switch so whats the difference... thats all no biggie..
stickboy1375 said:I would only use whats approved for a switch... does anyone have some pics of newer weather proof switch covers?
kbsparky said:How about this one?
