mshields
- Boston, MA
Came accross a situation where an illuminated sign rated for 277V was running at 120V. PM wanted to know how that could be. The sign was an LED type. I said that this was a resistive load. V=IR therefore if you run it at a lower voltage you get less power and less light. If you do the opposite you'd obviously burn out the fixture given that you'd be running higher current through the fixture that that which it is rated for.
But it got me thinking, how would this work with a ballasted fixture. Are ballast just resisters. Clearly not in the case of electronic ballast right?
So what would happen if you took a 277 rated fluorescent or HID and tried to run it at 120V. Anybody?
Thanks,
Mike
Thanks,
Mike
