depcdivr
- spring lake, NC
- engineer
This may be a simple question for many of you to answer but its got me stumped.
I have the following situation:
Hall light with three switches. The two end switches are 3-Way and the middle is a 4 Way. I am not sure how they are wired at the moment because It was existing in the house.
This is how it operates. If the lights are On then any of the three switches can turns the lights on/off. If you turn the light off by a 3 way switch then the center(4 way) switch will not turn the lights on again. Either of the 3-way switches will turn the lights on if actuated. Then when the lights are on the 4 way can turn the lights off and on again. Until it is turned off by a 3-way... and on and on it goes.
I understand how the wires are travellers are supposed to run and how it is supposed to operate but I can't wrap my head around how the circuit is actually connected to give the results above. Anybody have any thoughts on this schematic?
