Its probably in the building code.
I would think egress.
I will say no. You may find something in the IRC if it is a one or two family or the IBC if three or more. You could ask the same question is a receptacle required.Are lighting fixtures required on balconies in a multi-story multifamily building I cannot find anything into 210.70 that says they are
Sent from my SM-G950U using Tapatalk
Unless there was changes since 2008, first floor isn't the determining factor - grade level access is.It's pretty clear in 2008that receptacles are required on any balcony in my opinion. I also am pretty sure it's silent on a light fixture on that same balcony, unless like mentioned above it's on the first floor or is an entrance or exit
Well said and I do agree, by 1st floor I do mean grade level.
