drbond24
- Barboursville, West Virginia
Before I state my problem, let me avoid sermons by explaining that I realize that this is the lightning forum (extra 'n') and I am asking a lighting (no extra 'n') question. I'm here because of the power quality part. :grin:
I have two problems that may actually be one problem. First problem:
We have a warehouse that is illuminated with 400 W metal halide fixtures. These fixtures go dim extremly quickly A brand new bulb will be down to about 50% in a week. These bulbs should not noticably dim for at year, even if ran continuously. What could be causing this? All I have done is check the voltage on the lighting circuits, and the highest voltage I found was 287 V on a 277 V circuit. Not high enough to be a concern.
Second problem: We have a manufacturing plant that sits right next to the warehouse, but each is fed with a separate service. They are supposed to be independant of one another. However, any time the manufacturing plant loses power for any reason, after about 4 or 5 hours the warehouse will go down and we won't be able to get it on again until the plant is on. Last time, the warehouse burned a ballast in one of the aforementioned lights which apparently happened right before the whole building went off.
Now, is that one problem or two? Does it sound like there is a connection between the buildings that shouldn't be there that is causing both problems? Any input will be appreciated. If more details are needed just ask and I will provide them.
