Lighting
john d
Florida
Does the NEC refer you to or require you to follow the International Energy Conservation Code or ASHRAE 90.1. as it pertains to lighting. Since the architect and/or interior designer choose fixtures is it their responsibility or the electrical engineer to meet these codes.
Does the NEC refer you to or require you to follow the International Energy Conservation Code or ASHRAE 90.1. as it pertains to lighting.....
No.
I believe it's alocal thing.
If the jurisdiction adopts the IEC, then it would be the engineers responsibility, as it should be addressed at plan check.
I bring this up again and again, do not get into the habit, as an electrician, of thinking that the only code you have to follow is the NEC.
