I live in Sri Lanka. Can someone help me with 2 questions please:
1. To protect a steel industrial chimney against lightning, do we need to install a lightning rod at the top of chimney and use a down conductor and ground it or is it sufficient to connect the grounded earth electrodes to the chimney from the bottom i.e. let the steel chimney act as the conductor?
2. Do you need a lightning rod at the top anyway as the steel chimney can be the conductor?
