Lightning Rod conductor
I rewired an old courthouse years ago ( It was built in the late 1800's) The main structure was wood with a brick exterior, The clock tower had a lightning rod on top with a pre-attached wire to run down. The historical committee wanted me to run it inside the building down the wood beams. I did not feel that this was a good idea, as a strike could superheat the conductor catching the wood on fire. I did not want to take that responsibility and refused to do it. they of course found somebody that would take the risk. I have found that lawyers will still try to hold you responsable even if the engineer told you it was ok.
It can be run in the wall. The down side (pun intended) in my opinion is that if there is a strike, the movement of that conductor within the wall will damage the wall. I usually have it run on the outside of the building sleeved in PVC as needed.
I've seen old building where the copper down conductors were solid bars that had developed a very nice patina.
-Jon
And they also bring some pretty good money from the scrapyard. I tore some out of a bank building not too long ago. It was 6 stories tall and had 6 down conductors about the size of 3/4 copper pipe. Engineer wanted this replaced with modern lightning protection equipment
