I have been working on a job that has been shut down over and over due to lightning.The building is only a metal structure at this time 5 floors.
One of the G.C. Employees is saying all the electrical contractor needs to do is install the lightning protection and the building will be safe ,I think he is wrong I know the lightning pro. system will provide a direct path to ground but I do not believe that this will be the only path it may take. drawings show us to install lightning rod at top and ground rod at bottom of every column both will be cad weld connections to the column, all along the outside edge of the building.the columns sit on concrete peers drilled about 80 feet into the ground does the 80 feet deep help with this issue and how will the concrete effect it? how would the lightning rod and the ground rod improve this?
thanks for any comments,
mark
mark
