Flicker Index
- Pac NW
- Lights
Dishwashers generally use a permanent magnetic synchronous motor for drain pump and it is cycled repeatedly. The main pump is generally an induction motor but newer machines are using DC motors with rectifier.
LEDs are intrinsically extremely susceptible to flicker, because they have basically zero inertia. So little that you could modulate LEDs quick enough to not be noticed by people yet carry data in the light wave. LEDs are entirely dependent on its ballast to not pass on undesirable effects into light. Inductive kickbacks can cause LEDs to act out, especially those that is built with a dimming ballast even if it is not used with a dimmer. The LED ballast controller can interpret it as dimming signal and abruptly activate dimming.
Really all you can do is throw parts at it. Try different brands and different generations of lamps/bulbs/fixtures as each LED ballast design responds differently to interference.
