richmacary
I have an issue with lights flickering. The local utility checked the line to the main and replaced it. I have 2 - 200 amp main disconnects outside the house with to 2 - breaker panel boxes in the garage.
A volt meter checking one boxes shows 124 volts when testing from neutral to each leg. The same test performed on the other box shows 133 volts on one leg and 115 volts on the other. How can this be? I also noticed about 9 volts when testing from neutral to any metal surface in the box.
Any ideas?
Any ideas?
