I have to go to a call Friday. The homeowner says that everytime she runs the vacuum cleaner on a particuler circuit her lights go off, but the breaker doesn't trip. Anyone ever seen this type of thing before? Any help is appreciated.
Loose or open neutral. Classic case.
Couldn't it also be a loose or open hot?
This missing neutral could be in a box splice, Or in a ******** spliced receptacle, or coming from the street or panel equipment. you tell your customer to shut the lighting circuit off immediatly
Questions:The homeowner says that everytime she runs the vacuum cleaner on a particuler circuit her lights go off, but the breaker doesn't trip.
You could have a missing hot leg usually caused by a bad main breaker, it could be a neutral, but usually with a open neutral you would have the lights getting brighter when the vacuum came on not going off.
