line and load conductors in same raceway
sparkmantoo
Virginia
a 1ph 208v circuit feeds a disconnect. the disconnect is for a fan. if you run the line and load wires in the same raceway, do you count all of the conductors as current carrying, or do you only count one set?
don_resqcapt19
Illinois
retired electrician
Re: line and load conductors in same raceway
You count them all. They all produce heat the derating is intented to limit the heat produced in the raceway.
Don
