electron_ranger
- Lilburn, GA
Line-side "tap" and max. current back-feed thru Utility XF
500kva utility, pad-mounted transformer
400A 480/277v MSB to the building
I need to calculate what the maximum size PV array is that I can connect. It'd be a line side tap for sure, and I'd have to upsize the conductors between the tap and the XF I know.
Question is, how many electrons can I push backwards through that 500kva transformer? If I said that NEC section 450, Transformers, doesn't apply to utility owned transformers, would I be right? Is that a trick question?
Thanks for any suggestions or code references on this.
-Montana B.
-Montana B.
