Article 705.12(A) allows for an interconnected electric power source on the line side of the main disconnect as permitted in 230.82(6), if the power source consisted of 4 utility interactive solar inverters would it be permissable under 705.12(A) to connect the A/C output of each inverter to a panelboard with 4 branch ckt breakers, and then feed the panelboard from a line side tap at the mainservice disconnect?
