Discovered a lighting panel in our plant which is using a three-wire system. Instead of a neutral wire they are using the building ground for the neutral. We do have a 277/480 Wye system in our plant.
I will run a new service to this panel to eliminate any safety issues. My question is where in the N.E.C.does it state that you cannot use the ground for your neutral?
