I only use it to seal splices on my boat and trailer wiring....76nemo said:IMO, gooey bologna. Give me an example of where you'd use it. That is about as generic as I can think of
chris kennedy said:I don't know what brand the OP speaks of, but I carry a can of 3M scotch coat on the truck for temp repairs.
roger said:I used to turn wing nuts upside down and fill them with Scotch Coat in ground level boxes for water proofing.
One caution though, don't ever let the can fall over in the truck or tool box, no matter how tight you put the cap back on after opening it, it will seep out.
Roger
Very true.roger said:One caution though, don't ever let the can fall over in the truck or tool box, no matter how tight you put the cap back on after opening it, it will seep out.
Roger
nakulak said:we use something like that 3m stuff to repair the coating on robroy if it gets damaged.
zappy said:anyone see that stuff at the depot in the electrical isle.comes in a can.no ul listing on it.anyone use that stuff seems like a good idea for hard to tape wires.
RayS, Just wondering if that product is approved for potable water?RayS said:I've used it before in between layers of tape on well splices that would be submerged.
Also potted some hi density electronic connectors in it- when ya can't use heat shrink.
Also tried to glue some plier handle cushions back on with it, but that didnt work too well.
Roger
RayS said:nope, ya don't want to take 'em apart, although a split bolt with tape and mastic is worse...
stickelec said:I agree, the best way is....
iwire said:Is to forget split bolts where ever popular and switch to pre-insulated connectors or connectors that use a snap on boot.
