I have an RFI from an EC requesting to use "Liquid Nails" as an adhesive to secure metal outlet boxes to concrete ceilings and floors. Apparently, the nearby tenants have been complaining about the noise of drilling holes for bolts. I know the NEC requires the boxes to be secured. But is this an acceptable method?
if the adhesive is supporting only the box, it's probably not an issue.
if the box is supporting a light fixture, i wouldn't.
gas operated pin guns work pretty well. they don't hit as hard
as a powder LV gun, but you can fire repeatedly to set the pin.
also, you can pin the straps down, and it goes fast. the gas cartridges
don't seem to store worth a damn, however. they go flat once opened
pretty quickly. but in occupied TI work where i've got to shoot ceiling
wires, it works well. i've never had people complain about it.
i've got the little Milwaukee hammer drill that has the accessory
dust vac, and that is pretty quiet, and doesn't leave any mess behind,
and will punch 1/4" holes all day long.
