Why????
I do a lot of machine controls in plants mainly. If it is an outside or wet job I try to use fiberglass and/or plastic to keep corrosion ti a minimum.
I don't know for sure but doesn't metallic have a greater mechanical strength? Like resistance to crushing? If you pinch a non metalic and compromise the cable integrity it is usually a little harder to tell. The non metallic has more of a memory in the plasticity phase then the metallic does. Once your crush the metallic it stays mostly flat and a lot of the time it will short to the metal liner and cause a fault condition.
I probably just learned from some old timers that where set in their ways and it got drilled into me.
